Ramp Graph varies Time by using DAQ with PXI-6221
Hello Friends;
I have the task by using the LabView with DAQ for controlling the voltage Analoge Output with PXI-6221. By controlling the voltage, I have to monitor the ramp graph through Oscilloscope. I have to programm the task in order I could monitor it through Oscilloscope. The following details are describe how the Ramp Graph works:
  • from 0s - 10s = 0V constant
  • from 10s - 20s = 5V (the Voltage shows ramp curve)
  • from 20s - 80s = 5V (the Voltage is constant)
  • from 80s - 100s = 0V (the Voltage shows de-ramp curve)
  • from 100s - 110s = 0V constant
The following attachment shows us the curve that is going to monitor in Oscillospoe through LabView Programming by using DAQ Communication.
Anyone could help me to guide it properly?
(2,144 Views)
Hi Aidylzaid,
use the triangle generator and chop its output.
See example in the attachment.
Best Regards,
NI TSE
(2,087 Views)
And the attachment again...
(2,086 Views)
