Read a serial data with PCI 6024E
I need to read a 2MHz serial data from a AD converter. I was trying to read this serial data using a digital input channel, but I need to synchronize the frequency of maltab read and the serial data frequency. How can I do this?
Thanks!
(3,377 Views)
If your Digital Input has hardware timing and can use an external clock, then use the conversion clock from the A/D converter to clock the DI lines.  Note that A/D converters may have several timing signals.  Read the data sheets and find the right one.
Lynn
(3,374 Views)
Ok, johnsold. Can you send more details about this procedure, please?
(3,366 Views)
I am not familiar with the PCI 6024 and you have not specified the A/D converter.  I would need to take the time to study up on both to answer in a meaningful way. I do not have the time now to do so, and you could probabbly do it about as fast.
Lynn
(3,362 Views)
A quick look at the specs and you would see that the digital I/O is software timed and you won't be able to sync to that high a speed. You'll need a better card.
(3,359 Views)
