Read actual pulse frequency rate
When I set up a counter to generate pulse train using "DAQmx Create Channel (CO Pulse Freq)" and provide  some arbitrary value to "frequency" input, can I read the actual rate value?
SampClk.Rate property on DAQmx Timing node returns zero.
(3,367 Views)
Accepted by topic author Fedor
Never mind, turns out counter freq. shows up in DAQmx Channel node. Go figure.
(3,366 Views)
