Read data of a Pci DAQ-Card 700
I am using: the labview DAQcard-700, with NI-DAQ 6.9.3 on labview 8.2, the higher DAQ drivers have been removed as per NI requirement to use older cards
The device is detected correctly through the Measurement and automation system on labview
Basically i can run the test panel in Measurement and Automation, but i haven't the first clue about how to read this data into labview other than i must use the DAQ legend pallette.
Does anyone have a simple read and disply VI that they could post here or tell me how to do.
I'm at a bit of a loss.
Many thanks
John P.
(2,815 Views)
I have found that a number of examples within labview examples actually cover the requirements.
opps.
Thanks anyway!
(2,810 Views)
