Read thermocouple with offset
I am trying to read measurements from a thermocouple continoously using a buffered operation. If I don't use the offset node then this runs perfectly. I now want to read this operation with an offset but this does not work. I get no values at all.
It returns also the following error:
Untitled 1<append>
<B>Property: </B>RelativeTo
<B>Corresponding Value: </B>Most Recent Sample
<B>Property: </B>Offset
<B>Corresponding Value: </B>-2
<B>Task Name: </B>Temperatur
My code is attached.
(3,437 Views)
Hello Duncan,
I have a few further questions to ask you:
First of all, which versions of DAQmx and LabVIEW are you using? Could you also tell me what happen if you set the offset valur to 0. Does it work again or you also get no values at all? One last thing to think about is the execution of the node. Properties are executed from the top to the bottom. I am not very familiar with DAQmx in LabVIEW so I can not tell you if the order of execution of the properties plays a role in that case but it could be something to check.
Regards
______________
Florian Abry
Inside Sales Engineer, NI Germany
(3,418 Views)
Thank you for your answer!
I am using LV2010 SP1and Daq 9.3.0f2. If I set Offset to zero it works again.
I can play a bit with the nodes and will tell you if something changed.
(3,415 Views)
Hi Duncan,
Can you tell me which card you are using? I tried your program with a simulated M Serie card and two channels. It looks like working almost properly. Almost because it works in highlight execution but not in normal execution. Can you check if in highlight modus it works also for you? If so, adding a short temporisation after starting the task should solve your problem.
Regards
______________
Florian Abry
(3,411 Views)
Yes it actually runs in highlight execution.
I think that solved the problem. Thank you!
(3,408 Views)
