ReadMultiSamples from MultiChannels - old values arrive
Hi!
I have a problem with the program which is included in the post:
I am using  DAQMx with my PCI-MIO-16E-1 card.
I just want to read in some voltages from all AI in a single task.
In my constructor I have declared the things. (look at the program code).
The only problem is, if I run the method "getAI" in a loop, I get old values, so If I measure with the multimeter and increase the voltage, on my pc it only shows realtime values 1-5sec later!
why that?
I have 200Hz clock rate, and want to read with ReadMultiSample 10 Samples.
I used: Stream.ReadOverwriteMode = ReadOverwriteMode.OverwriteUnreadSamples; in the constructor, to be sure, that if my loop is too frequently, not the old 200 values which are stored in one second are used.
Is this right?
How can I get real Time values?
Please reply!
Thanks a lot!
Yours, Klaus
(3,204 Views)
(3,196 Views)
Are you sure, that you are using a differential input configuration?
Try
AITerminalConfiguration.Rse
instead.
(3,194 Views)
yes sure, differential..
my loop takes sometimes with other pheripheral 65ms, and so I think I read old values from the buffer...
(3,185 Views)
