Reading AI from two devices at different frequency in C#
Good day all,
I recently started working with NI DAQ cards, namely CDAQ and USB 6008, I am trying to read 3 channels AI from CDAQ at 10KHz and 1 AI channel from USB 6008 at 1KHz and then print to a csv file.
What i found in the examples was a multi-device synchronized continuous AI read. This example allows me to read the two devices at the same frequency. but I wanted to know if there is a way to read two devices at different frequency and display the data to DataTable in C#.
Any guidance will be highly appreciated.
Thank you.
(2,449 Views)
