Reading binary values with NI-USB 6008 using NI-DAQmx base 1.4 and visual C++
I want to know how to read binary values of an Analog input channel (samples are acquired continuously at 1Khz).
I tried to call the function "DAQmxBaseReadBinaryI16" with an array of 16 bits integers but it always returns the error code -200428:'Value passed to the Task/Channels In control is invalid'
Should i always use "DAQmxBaseReadAnalogF64" with a double precision floating points array,
or did i forget something in the channel configuration?
(I used the same configuration in the 2 cases but the first doesn't work)
This is approximatively what i've done
//channel Configuration
DAQmxBaseCreateTask("",&taskHandle);
DAQmxBaseCreateAIVoltageChan(taskHandle,chan,"",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,NULL);
DAQmxBaseCfgSampClkTiming(taskHandle,clockSource,sampleRate,DAQmx_Val_Rising,DAQmx_Val_ContSamps,samplesPerChan);
DAQmxBaseCfgInputBuffer(taskHandle,100000);
DAQmxBaseStartTask(taskHandle);
//reading
//this call works
DAQmxBaseReadAnalogF64(taskHandle,pointsToRead,timeout,DAQmx_Val_GroupByScanNumber,/*float64*/data,bufferSize,&pointsRead,NULL);
//this call returns the error code -200428
DAQmxBaseReadBinaryI16(taskHandle,pointsToRead,timeout,DAQmx_Val_GroupByScanNumber,/*int16*/data,bufferSize,&pointsRead,NULL);
(4,309 Views)
You cannot read 16 bit Raw data with a USB-6008 device that has a 12 bit resolution. This option is only available for 16 bit devices.
Regards.
JV
(4,284 Views)
Regards.
JV
Actually, at least for DAQmx Base on Macintosh OS X, the ReadMe file shows this:
NI USB-9211
*Analog Input
-Multi-channel, multi-sample read (scaled)
-Multi-channel, single sample read (scaled)
NI USB-9215
*Analog Input
NI USB-6008/9
*Analog Input
-Digital start triggering
Note that none of the supported USB devices supports raw input mode, even the 16-bit 9215.
It was surprising hardware and software limitations like this, plus missing functionality (most notably the lack of Properties available in NI-DAQmx) that convinced me that I can't develope a commercial-quality product based on DAQmx Base.
John Weeks
WaveMetrics, Inc.
Phone (503) 620-3001
Fax (503) 620-6754
www.wavemetrics.com
(4,281 Views)
thank you for the answer.
(4,269 Views)
NI-DAQmx 7.5 (link below) now supports the USB-6008 and USB-6009 devices on Windows.  I strongly recommend installing this much more powerful and robust driver.  For more information on how to switch your device to use NI-DAQmx, refer to the KB linked below.
NI-DAQmx 7.5
http://digital.ni.com/softlib.nsf/websearch/CF7ECCEA4C4CC7DE86257038004D88AE?opendocument&node=132060_US
KB: 3NE7GJMY
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YIRDCA4&l=en-US
(4,099 Views)
NI-DAQmx 7.5
KB: 3NE7GJMY
Back from vacation...
Yes, the commercial-grade product was developed with NI-DAQmx. I learned about all the limitations of NI-DAQmx Base in the process of trying to port it to Macintosh.
We still don't have a commercial-grade solution for Mac OS X.
John Weeks
WaveMetrics, Inc.
Fax (503) 620-6754
www.wavemetrics.com
(4,076 Views)
