Reading differential signals with USB-6210
I am trying to read differential signals from an accelerometer with an NI USB-6210 mydaq. We have previously written code for a different pair of accelerometers that used a reference voltage rather than a differential signal and the code is such a mess that I'm having a hard time figuring out how to change it for this new device. I tried using NI examples for differential signal measurements but it doesn't seem to show any difference when the accelerometer is shaken (if it's even supposed to). At this point I just don't think I know what I'm doing and could use some help.
For reference, the accelerometer is connected to an external power supply at 10 Vdc. The +OUT wire is connected to terminal AI0 and the -OUT wire is connected to terminal AI1. The accelerometer measures 0.1269 mV/g up to 2000 g's with a zero acceleration output of +-25 mV. The example VI I am attempting to use is "Voltage - Continuous Input.vi"
(4,965 Views)
The 6210 and the myDaq are two different devices. Which once are actually using? For the 6210, ai0 and ai1 are certainly wrong for a differential measurement. You would connect ai0 and ai8 and specify just ai0 as the differential channel.
(4,958 Views)
Oops, we're using the 6210. We were originally using the AI0 and AI8 terminals but another of the example VIs said to connect to 0 and 1 so I just left them in there after trying.
(4,955 Views)
