Reading two analogue signals
Dear Mr. / Madam,
I want to read two analogue signals in the same time... In the program you might see in the attachment file, I fail to read two analogue signals for unknown reason... while if I read one I don't have the fail situation.
Noticed that I write one analogue and another digital signal in the same program.
Further I have DAQmx (NI 6251) as a Labview Card.
Thanks in advance
Ali Al-omaishi
(2,888 Views)
The error you get and the code has been the subject of numerous posts and is a very known problem with beginners of data acquisition. Did you try to do a search?
You simply cannot have two tasks for the same resource. Use a single task with mulitple channels.
(2,887 Views)
