Receive errors when building my Installer app.
I receive this error message when I try to build my Installer app.? Please advise.
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_PreBuild.vi >> CDK_Engine_FileExists.vi
(3,590 Views)
Hello craszy,
It is difficult to determine any details about what you are doing from your post, but I am guessing you are building your application and receiving errors at some point during the build.  What is the project like that you are building?  What type of installer are you creating – what are the settings, and are you including any additional installers with your application.
We do have a couple instances of this error on record.  Most of them occur when you are including our DAQmx installer as an additional component to your installer.  Can you build your installer without the inclusion of additional installers?  Can you attach a screenshot of the error?
You also might want to check out these links
http://forums.ni.com/ni/board/message?board.id=170&message.id=154868&requireLogin=False
http://digital.ni.com/public.nsf/allkb/c3666ba408f81e59862570d20056e692
I also found another instance of this error when the user had an unusual installation of DAQmx.  In this user’s case, uninstalling DAQmx, and reinstalling the driver with LabVIEW 8.0 support only seemed to fix the problem.
Please let me know if any of this helps, or if you can provide some additional information.
Thanks, and have a good weekend!
Travis M
LabVIEW R&D
(3,573 Views)
