I am working on updating a LabView program that was written in LabView 2 or even possibly earlier. I got the conversion CD and upgraded the program so I could open it on LabView 6.1. Unfortunately, in the process of this upgrade, all information regarding the access to the lines of the board was lost. At the time it was last used, it accessed a Multifunction I/O Board for Macintosh Nu-Bus, Part Number 320174B-01 and was using a Macintosh IIci computer. I have a new DAQ board, the NI-PCI-6221 that is in a new Dell workstation, running Windows 2000 and LabView 6.1. I was wondering if there is a way to recover the channel lists that should be in the subVis. Do I need to track down a copy of LabView 2 or 1 to do so? This conversion also involved a Macintosh to PC switch, which if I understand correctly is a problem in the earlier versions of LabView? I was hoping to find the best way to recover this information, so I can properly adjust the program and configure it to my new DAQ board. Thank you.
Kathleen
