References in Visual Studio 2005
What happened to the references for common and ni4882 in VS.Net 2005????
Damn it Microsoft.
(3,735 Views)
When you installed NI-488.2, did you enable support for .NET 2005? If not, you can go to Add/Remove Programs, click on National Instruments Software, and select change. Select NI-488.2 and click modify, and select .NET 2005 support from the software installation tree. Thanks!
Ebele O.
(3,713 Views)
I have NI-488.2, but it is not coming up. Im assuming I need to download the latest drivers.
NI-DAQmx Version 8.3 for Windows 2000/XP?
Thanks for your help.
(3,686 Views)
Yes, you will need to download the latest NI-488.2 driver for VS 2005 support. Here's a link to the download page. Thanks!
Ebele O.
(3,682 Views)
