Regarding DAQ data acquisition
hello All,
I am new to DAQ acquistion of data, can you please provide me samples how to read 1000 sapmples per channel for 1 sec upto 8 secs.
and also i want to repeat this sequence for every one minute.
Thanks in Advance.
(3,570 Views)
I would suggest you go to the DAQmx Getting Started page. You should also provide the programming language you are using if you want to be pointed to example programs. Don't you think that is important information to include in a question?
(3,542 Views)
Hi Rajeswari,
I agree with Dennis that you need to quote the software you are using. We can safely assume it to be LabVIEW, bt we still need the version.
I am attaching a code below in LabVIEW 8.6 . Please tell me if this helps.
Best Regards,
Shivam Awasthi
(3,515 Views)
