Replacement for cDAQ-9172
I have a machine that has a NI cDAQ-9172. I know this hardware is no longer supported. I want to replace the chassis only if possible. I saw in another post that NI cDAQ-9178 is a replacement so I have two questions:
1.) Is NI cDAQ-9178 the latest chassis that can be a direct replacement for cDAQ-9172?
2.) Will the modules currently in the cDAQ-9172 work in the new chassis?
Thank you in advance.
Message 1 of 1
(1,051 Views)
