Requirement of administrative right of PC
Dear all,
we are using our own software which uses USB6211 (and its driver software) as data acquisition board. We have noticed that we always need Administrative right of PC for running the software which uses the board USB6211. Is there any way to get rif of requiring administrative right to use this board?
Thanks.
(959 Views)
Hi  kisla
These steps show you how to set Windows security settings to give non-administrator users full control over NI software, problems can occur if you need to upgrade software or force re-install corrupted files. The lack of Windows administrative privileges can also result in certain NI software features becoming unusable, which may include:
  • Not being able to access Test Panels in Measurement & Automation Explorer (MAX)
  • Not finding GPIB Instruments when using the Scan for Instruments functionality in MAX
  • No folders under My System in MAX
  • Not being able to use the DAQ Assistant
Find more information from this article.
Regards)
(889 Views)
