Reserve network
hello,
I have two devices modules Ni9181 wiht 9102, and I did a program which the user can select wherever module, and start the adquisition. The problem is that before run it, is it needed reserving chassis and do a self test, because otherwise it doesn't work.
So I wanted to know if it is possible do it by code, I tryed to add moduls like Add Network device, and Reserve Network decive, but it doesn't work.
the final program should be an exe where it can be executated in some pc.
could anybody help me?
Thanks in advance,
ATO
(3,254 Views)
anybody can help me please?
(3,239 Views)
