Reserved resource error with NI 9219 module
I am using NI 9219 module to read 3 analog inputs (2 current and 1 voltage).  I have two VI's one for reading the current output from pressure transducers and one for thermocouple. When I run them simultaneously I get error relating to reserved resource and only of the data is read. How could I remove this error and get data from the the pressure transducers and thermocouple simultaneously. Thanks,
Ketki
(4,209 Views)
Accepted by topic author ksharma77
Did you do a search for that error? It's a very common mistake. You have to have all measurements in a single task.
(4,206 Views)
Ok. Thanks ! I put them in a single task and was able to resole the error.
(4,187 Views)
