Reset AO in USB6009
I am learning the application and got a questiona about how to reset the AO just like no output at all.
for example, I set AO1 to 3V and do some tests, then I need to reset the AO and do next test.
should I set the AO to 0V every time or is there any VI that will reset to channel to default status?
I tried task stop and task clear. when the VI stop, the channel is still with the output voltage set in the code if I don't set 0V output.
thanks a lot for your help
(3,118 Views)
By doing a DAQmx Write of 0, you are doing the correct thing.
(3,112 Views)
In addition to what Dennis mentioned, it might be useful to also know that the " DAQmx Reset Device" VI will reset all the channels on the device.
Faris
Bueller
(3,097 Views)
Message Edited by gunking on 07-30-2008 01:33 PM
(3,090 Views)
