Run 64-bit card on same PC, but different times, as my 6110?
I want to run a PCI-x on the same PC, but at totally different times as my NI PCI 6110.  Are there any foreseeable problems with this?  Thanks
(2,909 Views)
Hello bosshog,
Thanks for your post!
I see that you are using NI-PCI 6110 and another PCI-X in the same computer. The PCI-6110 gets its power directly from the 5V rail so you can run into problems if you have 4 or more of the cards in the system. So if you have at least a 250 W power supply or more in your PC than I would not anticipate you to run into any problems. Please report problems immediately if you do run into any.  Let us know if this answers your questions/concerns about using PCI devices.
Cheers!
Corby_B
http://www.ni.com/support
(2,892 Views)
Yes, thanks.
(2,887 Views)
