I've written a simple program on MS Visual C++ 6.0 to test my PCI-6014 board and it works fine.
I copied the code to Borland C++ builder 5.0 and had some linker problems with the .lib files that where solved with borland's "coff2omf".
Now I've been getting run-time errors when I use the function DAQmxCreateAIVoltageChan()... The error code is -50251: "The specified software component is not available. The component was not loaded".
But I'm sure that the code is right, since it works fine on MS Visual C++ 6.0!
That the part of the code where I'm getting the error:
iErro = DAQmxCreateTask("", &thTask);
iErro = DAQmxCreateAIVoltageChan(thTask, "Dev1/ai0", "", DAQmx_Val_Diff, -10.0, 10.0, DAQmx_Val_Volts, NU
LL);
Thanks for the help,
Marcelo
