Run-time Error: 10370, Configuring Channels.
I use a PCI-MIO-16XE-10 card in my computer to connect
to a SCXI-1000 chassis.(The parts that are connected to the chassis are SCXI-1349,SCXI-1141.)
I am getting the following error.
"Run-time error '10370':
Configuration channels
The scan list is invalid; for example, you are missing
AMUX-64T channels and onboard channels, scanning SCXI channels out of order, or have specified a different starting channel for the same SCXI module.Also, the driver attempts to achive complicated gain distributions over SCXI channels on the same module by manipulatingh the scan list and returns this error if it fails."
Please Advice.
(2,951 Views)
What exactly are you using for the scan list?
Mark
(2,951 Views)
AI tab, +/- 10v, Differential Input
AO tab, bipolar
The gain = 1 on all channels except channel 7 the gain = 10.
(2,951 Views)
That's the settings. By your answer, it sounds like you're using the NI-MAX. Are you getting these errors in NI-MAX, or LabVIEW?
If you're getting them in LabVIEW, what do you have wired for the channels to be scanned? (i.e. "ob0!sc1!md1!0, or a virtual channel)
Mark
(2,951 Views)
