Running niusb9162dlfw fails with a core dump
I am trying to test the functionality of the USB-6009 under Red Hat Enterprise Linux 5 and I get the following error when I attempt to update the firmware using niusb9162dlfw, Aborted (core dumped). However, if I run the FWUpdate utility, I am able to update the firmware on this device. I need to be able to use the command line utility to update this firmware. Do you have any idea why it is failing?
(3,022 Views)
Hi Raynard, Thank you for using our discussion forums.
The niusb9162dlfw is a complied script for the 9162 USB sleeve, and currently the FWupdate utility is only way to update firmware on the 6009 so currently there is no way to perform a Firmware update from the command line.
Chris
Message Edited by Chris_K_ on 11-13-2008 10:18 AM
(2,990 Views)
Thanks Chris
(2,984 Views)
