SCB-100 standoffs
I would like to order some male-female threaded standoffs identical to the ones used on the SCB-100 100 pin connector.  Could you tell me what the part number of these standoffs is?  It looks like the male thread is 4-40 or 2-56 while the female threaded opening is 2-56.
Thanks.
(3,021 Views)
Hello jrs2,
Thanks for contacting NI.  The information you are looking for can be found in the following Knowledge Base:
Specifications and Dimensions of Jacksocket Screws Used on 68-Pin Board-Mount Connectors
I hope this helps!
(3,006 Views)
