SCB-68A Connector Block
We are currently designing a board to interface with DAQ 6361 (Mass Termination)- we are planning to use a SCH68-68-EPM cable between the DAQ 6361 and the PCBA.  The PCBA will therefore have the same 68 pin connector as the SCB-68A Connector Block- what is the part number (or equivalent Molex/etc part number) of the 68 pin connector on the SCB-68A board.
Alex
(4,234 Views)
Take a look at this KnowledgeBase: Specifications and Manufacturers for Board Mating Connectors
I believe that the part numbers you are looking for are under the first section: 68-Position 0.050 Board Mount Connectors
Jeff L
(4,216 Views)
Just to make sure, 777600-01 connector will mate with the "blue end" of the SHC68-68-EPM cable?
Alex
(4,209 Views)
That's correct.
Jeff L
(4,187 Views)
