SCB68 - damaged channel
Hello all,
I am using a SCB68 and the AI0 is giving corrupted data. Instead of reading a 0N signal from a force transducer, I get 175N. And the signal does not change when applying force (It works fine apart from the noise with the other AI channels).  I want to be sure that this corrupted channel is not affecting the others. Is there a way to silence a channel?
Many thanks,
Amelie
(3,993 Views)
SCB-68 is just a connector block.
Choose a different terminal if the one you are using is not working.
(3,976 Views)
