SCXI-1000 green light flickering
I've been using the SCXI-1000 for almost two years now and today was the first time it required rebooting in order to function properly (although a reboot fixed the problem). In trying to figure out that I should reboot, I realized that the green button which indicates the chasi is flickering. It flickers from being bright green, to dim green, and seems to be doing so about once a second.
I would like to know if this is a fixable problem (perhaps some bad fuse) or whatnot, because I cannot have the the instrument bug out on me while I am running a test.
Thanks in advance.
(2,853 Views)
Hello AbsolutVa,
There is a Knowledge Base that talks about this. I would not think the fuse could be the issue since it is still working correct?
If you can, you can check them. This document help you get information about the fuses.
Hope this helps,
Gerardo O.
RF SW Engineering R&D
(2,843 Views)
