SCXI chassis not configurable
Good day,
i'm not able to change or select the proper/new Daq device to be connected to our "old" SCXI chassis.
see attachement.
I want to select Dev2 (usb 6361 daq) to be the chassis communicator. It doesn't appear in the drop down list. Only the simulated DMM (4065) appears ?????
regards,
Koen.
(4,956 Views)
Hi Koen,
My name is Joshua Young and I am from the Applications Engineering department at National Instruments UK.
Just to clarify some details, you have a SCXP 1001 chassis and want to use an NI USB-6361 as a chassis communicator in order to acquire data. When setting up in NI MAX you are unable to select the device in the drop down menu.
I have looked into the compatibility of the SCXI 1001 and X series cards. Unfortunately, the USB-6361 is not able to be used as a communicator with your chassis, hence why you cannot see it in the drop down menu. It only seems to be the USB-62XX devices from the USB range that are compatible with the SCXI-1001.
If you would like any more information on possible hardware solutions I would gladly help.
Kind regards,
Joshua Young
(4,881 Views)
Actually, support for SCXI over USB was added with the release of mass termination USB-62XX devices, but it's not exclusive to that group of products anymore.  The USB-6361 that Koen is using can be used as a chassis communicator.
Koen,
It looks like your system is not properly recognizing the 6361 as a Data Acquisition Device.  What happens if you try to self-test it in MAX?  What does it look like in Windows Device Manager?
(4,853 Views)
Good day,
the selftest succeeded ok & in the device manager usb6361 is seen as NI DAQ working properly.
Though not selectable/viewable in drop down for chassis communicator.
regards,
Koen.
(4,785 Views)
I now inserted a PCI 6221 NI card and I also can not select this card as chassis communicator.
(4,575 Views)
