STEPPER MOTOR
sir I want to interface stepper motor directly from the computer....I  took stepper motor program from ni example code on parallel port interface....the program is running sucessful but not the motor...
Message 1 of 12
(5,271 Views)
Can you post the program?
How is the motor connected to the parallel port?
Message 2 of 12
(5,262 Views)
yes, sir i'm send the link of that program....Actaully i'm very new to labview....i download the program from ni site itself...
http://zone.ni.com/devzone/cda/epd/p/id/3611
Is the motor will run without any necessary hardware i.e. i have the stepper motor only...?
Message 3 of 12
(5,253 Views)
You cannot connect the stepper up directly to the port- not enough voltage or current to drive it.
You could use something like this, depending on your stepper motor wiring, voltage and current requirements:
http://electronics-diy.com/electronics/stepper_motors.php
http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/connect.html
You may have to adjust wiring to the port or modify the LabVIEW program to toggle the correct lines on the port.
Here's some other links:
http://www.google.com/search?hl=en&q=%22motor+driver%22+%2B+%22parallel+port%22
Message 4 of 12
(5,253 Views)
Sir I got NIDAQ SCB-68....but i don't no how to configure it with the stepper motor ...please guide in this regard....
Message 5 of 12
(5,223 Views)
 My stepper motor specification is:
Permanent Magnet, Bifilar Wound, Two Phase Steps Per Revolution : 200
Step Angle :
1.8o + 0.1o Non-cumulative
No. of leads - 6
On request - 4,8
1 Kg. cm. = 0.1
N.m = 13.9 Oz.-in.
Drive Circuit
Message 6 of 12
(5,222 Views)
Sir i HAVE TBX-68T, SCB-68..........PLEASE GUIDE THAT WHICH THING I HAVE TO USE TO RUN STEPPER MOTOR....
Message Edited by hemantbhati on 04-16-2007 03:53 AM
Message 7 of 12
(5,218 Views)
The SCB-68 is just a connector block that is typically used with a DAQ card. It is not intended for use to connecting to the parallel port.
Do you have a DAQ card (if so which one) or are you trying to use the parallel port?
Message 8 of 12
(5,208 Views)
my DAQ card no. is 4351
Message 9 of 12
(5,197 Views)
The 4351 has 8 digital I/O available, which you probably need to connect to your logic controller. I presume the controller has an input to control direction and another that takes pulses to move the motor. With only digital I/O (no timer/counter on the 4351) you can do a timed while loop to control speed, but dont expect it to be stable or fast (only up to a few hundred Hertz)
Message 10 of 12
(5,178 Views)
