SUnMapLS_IP_EBP_8 error for Kernel32.dll
I keep getting The procedure entry point SUnMapLS_IP_EBP_8 could not be located in the dynamic link library kernel32.dll Does anyone know how to get around this. I am still using 6.9.1f28 Can I upgrade to 7.3 without any problems and not have the above mentioned error?
Thanks in advance for your time.
Jamie Gauthier
james.gauthier@ge.com
(6,332 Views)
What OS are you using? I looked in Kernel32.dll for WinXP and Win2000 and didn't see this symbol as an exported entry point. When are you getting this error? My suggestion is to use depends.exe which can be found on this page to find out what component is referencing this entry point. Post a screen shot of the depends output if you see something suspicious. I don't think upgrading to NI-DAQ 7.3 will affect this problem.
(6,329 Views)
