Safenet and port 6001
We have been using the USB-6008 in our products for some time. We also use the Safenet hardware protection keys. These are hard coded to use port 6001 and 6002. It seems that up until this week, there was an option of setting registry entries to insure that the National Instrument software did not use these ports. Otherwise it seems to default to ports 6000-6007.
In the last week, installations have been failing and no longer appear to reconize the registry entries. Is there some new procedure to get the system to leave the ports 6001 and 6002 available?
Are there specific modules which can be eliminated from the installation which will avoid this conflict? We only use a few API calls from a C program to access the USB-6008 device.
Message 1 of 1
(3,983 Views)
