Sample 6602 Counter in Position mode for one second at 100kHz
Hi again,
I was finally able to look at your Tester2.vi attachment on an LV 8 machine.  It appears that the test in question is a finite buffered position acquisition using a global channel.  And the "state" to restore is to have that channel revert to being in an unbuffered task so you can simply query a single reading of present value.
If I've got that part, then as far as I know, you *will* need to clear the buffered task before redefining a new one.  And if the RTSI connect / disconnect is necessary each time you do this test, there's probably not a better method.  If you *can* leave the RTSI connection active there's another possibility, but by the looks of things that's not likely an option.
I imagine the "filter" settings you referenced would also be a consideration, though I didn't see anything I could identify as filters.  Maybe they're in the CAN vi's?  I don't have CAN installed so those blocks just come up blank for me...
-Kevin P.
Message 11 of 12
(933 Views)
Tester2.vi didn't have the filter settings in it.  I was able to get it to work by closing and reopening the task after I was done working with it.
Thank you for your help again.
Jon D
Certified LabVIEW Developer.
Message 12 of 12
(922 Views)
