 HossIsAlright
			HossIsAlright
			01-16-2008 04:39 AM
 Christian Mergl
			Christian Mergl
			01-17-2008 04:36 AM
Hey,
The best would be to use an S-Series board which has independent ADCs for each channel, so you can sample simultaneously!
Christian
01-17-2008 07:42 AM
 Christian Mergl
			Christian Mergl
			01-17-2008 08:15 AM
Hey,
So if you wants to use your M-Series USB device the minimum delay between the channels would be somthing about 1µs. But you can determine this as described within the following KB: http://digital.ni.com/public.nsf/websearch/104E42830B2E2CE486256DBE005E68E4?OpenDocument
Christian
