Sampling
I have a DAQ card NI 9203, and I need to use it to collect data from 4 different instruments. Two of the instruments have a maximum sampling rate of 1 sample/ s and two of them have a maximum sampling rate of 100 samples/ s. Is it possible to use the same card?
(3,402 Views)
Why not sample at the higher frequency ( here 100 Hz) on all four channels??
You can always decimate the slower responding channels, offline
(3,400 Views)
Thank you for your reply. By decimate, do you mean apply filtering?
(3,398 Views)
Decimate (in this case) means discard 99 of 100 samples.
(3,378 Views)
