Save DAQmx scales in a project
I created a project containing some DAQmx Tasks and some Scales. I assigned the Scales to the Channels within the Tasks. This works fine. Now I would like to modify the scales in my LabVIEW application and store those new scales in the project. Is this possible? I know that it is possible to modify the scales and as long as the project is not closed the application works with the modified scales, but when I close the project these modified scales are gone. I am using LV 8.5.1. Thanks in advance
(2,857 Views)
Hi Steffan,
i don´t know if it is possible, but you can store the values in your own ini file. Or you write them in your project file (it´s an xml file).
Hope it helps.
Mike
(2,832 Views)
