Saving Calibrated/Adjustement Values for USB-6211
Hello all,
I am testing a NI USB-6211, and finding out of tolerance readings in the lower ranges for Analog Input (-1 V to 1 V) and (-0.2 V to 0.2 V).
Using the software I have available, LabView SignalExpress 2011, I see the option to calibrate this device and set new values. The problem I am running in to is saving these adjusted values to the device so that the input readings are accurate after I close the LabView program.
I am not overly familiar with LabView or other NI programs, so would someone kindly explain if the software I have is capable of setting the new values to the device, or what software would be needed for this?
Thank you.
Message 1 of 1
(895 Views)
