Scale switching in Max
How can I programitacly change scales in Labview.
I need to setup a device with 4 ranges/different scales for each range.
How can I accomplish this with Labview?
(3,054 Views)
Hello Dcarson,
I would first take a look at this Community Example and KnowledgeBase Article on how to programmatically create DAQmx custom scales in LabVIEW. Also, I would utilize a case structure in order in order to change between the different cases.
Best Regards,
Izzy O.
(3,045 Views)
