Scaling of Analog Input on SCC-AI03
I am working on a machine which uses a PCI-6036E going to a SC-2345 reading an analog input from a SCC-AI03. This system is running a custom VB6 application that reads and stores this value.
The system was running fine for about 4-5 years and suddenly would not read any values from the SCC. After performing some basic troubleshooting I determined that either the SC-2345 or the SCC-AI03 was bad. We purchased both components and I was able to determine that the SCC-AI03 was the problem.
Now, with the new SCC-AI03 installed, I am able to see the analog signal in the Test Panel but the value seems to be scaled wrong. When I measure the analog voltage with a DMM I see a value ranging from 0 to +3 vdc, when I view the signal in the Test Panel I see a voltage of -10 vdc to -7 vdc. The VB6 application is seeing the raw signal as well.
Ultimately I would like to scale the value so that 0 vdc = 0 psi and +3 vdc = 30 psi.
How do I perform scaling of this signal? Is the scaling stored in the SCC-AI03, the SC-2345, or the PC somewhere? I can not understand why the scaling was lost by swapping out the two pieces of hardware.
I want to try to avoid making any program (VB6) changes or performing any other software updates (NI drivers, MAX, etc...) because I don't want to cause any other problems by upgrading software. The system is currently using the Legacy drivers and I am hoping that the new components are still compatible.
Please Advise.
Thank You,
Bill
(3,288 Views)
Hi Bill,
Is your signal source floating? If so, the measured voltage might rail to that range. Make sure that you're properly ground referencing your source. Pages 5 and 6 of the SCC-AI Series Isolated Analog Input Modules User Guide provides details on how you should do this. Please post back if you have any questions. Have a great day!
Ryan D.
District Sales Manager for Boston & Northern New England
(3,264 Views)
