Scan clock enable
How do I enable scan clock output on an E series card?
I am using VC++6 and NIDAQ 6.9.1 and can't seem to find a solution.
(2,548 Views)
Hello;
The Scan Clock is an output signal by default, meaning that the signal pulses will show up at the correspondent ScanClock pin of the board connector.
You probably are having dificulties on seeing it since the pulse duty cycle is really high, meaning that the high pulse will occur for a small period of time.
To be able to catch those pulses, you will need to work with a high resolution Scope, on a smal timebase.
Hope this helps.
Filipe
(2,548 Views)
