Scope software for NI USB-9162 and NI 9215?
Hi Folks,
I have been gifted a NI 9215 USB one slot cDAQ chassis and 9215 4 channel analog input card. The kind person who gave it to me recalls using it as an oscilloscope with some software that came with it. Unfortunately he does not know where the disk.
Looking around it seems like there are two obvious choices that are wrong. NI-Scope is for high end digitizers. You can also create a task in NI-Max that looks very scope like, but seems to not have a trigger ability which is a must have for an oscilloscope. (There is a menu to set kinds of triggers, which only lets you select "None" or "Software".)
Does anyone know what this software might have been and where I might get it? Perhaps older versions of NI-Scope also worked on these devices?
Thanks!
(2,528 Views)
2verb,
Do you think he may be talking about the examples in LabVIEW that come with DAQmx?
These examples display a graph that may be what you are looking for.
(2,488 Views)
