Security PIN cDAQ-9181
Trying to turn on the GATEWAY using my Web interface to the cDAQ-9181.  It asks for a PIN.  What is it so I can disable it?!
(3,632 Views)
I am not so sure what are you referring to when you say PIN. I think that you probably mean that when you use the web interface it ask you for a username and a password. The default configuration or this device is Username= admin, Password= no password is required. To get the device to its original default configuration you need to just press the Reset Button for five seconds or more. You can refer o the user manual of the device, specifically page 28
https://www.ni.com/docs/en-US/bundle/cdaq-9181-9184-9188-9191-features/resource/372780k.pdf
(3,605 Views)
