Sending analog output signal from USB-6341 for a Biopac stimulator (STMISOLA)
Hi, I'm trying to utilise a stimulator (STMISOLA) in my setup. All the electrophysiological recording equipment belongs to NI.
Specifically, I want to send an analog signal to create a waveform for my stimulation protocol (square waves) and intramuscularly stimulate muscles while recording from the brain. I couldn't find a proper documentation on how to send send out analog signals from USB-6341. Do you have any suggestions?
(1,504 Views)
You've mentioned the programming language you're using, assuming you're using LabVIEW, there are a bunch of examples of using continuous or finite analog voltage output available from the Example finder as shown below.
Santhosh
Soliton Technologies
(1,487 Views)
I forgot to mention the software. All the equipment in my setup runs on Matlab. I'm not using LabView.
(1,475 Views)
My limited google search revealed this MATLAB page with examples - https://www.mathworks.com/help/daq/examples.html
Santhosh
(1,468 Views)
