Hello Mary,
First, you might want to wire a "TRUE" boolean constant into the "Append to File" input terminal of the Write To SpreadSheet File VI. The default value is false so the VI replaces data in an existing file.
If this doesn't correct the problem, would it be possible for you to post your VI so that we can take a look at how it is setup.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
