Sensors for BNC-2110 and PCIw-6321
Hello everyone,
I am developing some experiments for undergrade students. Our lab has BNC-2110 and PCIw-6321 DAQ system but I cannot find a appropriate sensors that can connected to the BNC2110 and get the measurements directly. Any recommendations please? Could be any of the temperature, force (load and torque), acceleration, displacement sensors. Many thanks.
(377 Views)
I am not sure where you are based so cannot recommend any specific websites/companies. However, in order to be compatible with with your DAQ system, you will need a sensor that outputs a compatible voltage range, through a BNC connector. Please see the datasheets on your devices for more info: https://www.ni.com/en-gb/support/model.bnc-2110.html?srsltid=AfmBOoqoiSIQ34uObLrorB0P-_MrwJSZn_pbQsk... https://www.ni.com/docs/en-US/bundle/pcie-6321-specs/page/specs.html. Note that you can also use digital output sensors with the BNC-2110.
Thanks, please let me know if this helps!
(314 Views)
Another solution I strongly recommend will allow you to use NI sensors is as follows:
You can purchase a SCB-68A (shielded connector block), this connects directly to your PCIe-6321 and will allow you to use screw terminals inputs with your PCIe-6321 (no need for the BNC-2110).
Most sensors from the NI shop will be compatible with the SCB. NI sensor shop.
(311 Views)
