Seperation of Analog Voltage Input data from the DAQmx read.vi output data
I would like to monitor multiple process values on a set of Mass Flow Controllers (MFC's).  I am using the multi-function DAQ board PCI-MIO-16E-4 for the voltage measurements/inputs.  I am having problems seperating the output data on the DAQmx read.vi.
I would like these voltages on the front panel along with the control voltages so I can monitor the difference between the set point and actual operating conditions. Typically I create a task to handle a number of similar events but I have never done this for analog inputs.  My problem arises when I am trying to seperate the different values from each channel exiting the output connector on DAQmx read.vi.
Does anyone have suggestions?
(2,903 Views)
I must admit that your query is not clear.
If you are reading single or multiple data samples from multiple channels, do as shown in attached pic to access the values from channels
Hope this helps.
If not, do get back
(2,896 Views)
