Serial port over run during deployment to TPC-2512
REceived the following error 62 while attemting to deploy a project over LAN to a TPC-2512 NI Touch Panel.
(3,004 Views)
Can you provide some more information on your problem?  Such as do you get this error when you deploy or while you are running the program?  What does your program do?  Are you using Serial for anything?
(2,993 Views)
