Set analog input DAQmx Task to RSE
I do not see the option to set the terminal connection type. I'm able to do so for analog output tasks and also for inputs on test panels. This also cause the connection diagram to be wrong.  How do I make sure the card is measuring with respect to AI GND not CH-?
(3,982 Views)
You did not provide the programming language you are using or whether you are using MAX to create the task or trying to do it in your code. Let's assume it's LabVIEW and setting the terminal configuration for analog inputs is exactly the same as setting the terminal configuration for analog outputs. Create Channel.PNG
(3,973 Views)
