Setra 264 Pressure Transducer wiring and settins to SCB-68
I'm not sure exactly how to wire the Setra 264 pressure transducer to the SCB-68.  Currently I'm powering the transducer with an external power supply and it is configured in MAX in "DIFF" mode.  I'm not comfortable with the readings so I suspect something with the wiring.  Does anyone have any insight?
Thanks.
Bobby
LabVIEW 2016 - Windows 7
CLAD
(3,354 Views)
Problem solved.  The installation guide for the 264 transducer has a misprint, the out terminal should be labeled negative not positive.
CLAD
(3,338 Views)
