Setting gain for PCI-6035E
I am trying to set the gain on my PCI-6035E in the Measurement and Automation software.  I can open the properties for the device.  Under the AI tab, there is a field that allows me to select the range.  The only option is -10V to +10V.  This board should also have other options down to -100mV to +100mV.
How do I set the gain?
(2,755 Views)
What version of MAX and DAQmx do you have? I just created a simulated device with MAX 4.5 and DAQmx 8.7 and can select different ranges.
(2,749 Views)
