Setting input range of the NI 9205 module
According to the manual the 9205 has four input ranges: +/- 10, +/- 5, +/- 1, and +/- .2 volts. Is setting the module to one of these four ranges accomplished by setting the min/max parameters of the DAQmxCreateAIVoltageChan function?
(3,463 Views)
Hi Bobcat
Thank you for using our discussion forums.
You are exactly correct.  The DAQmx driver sets which range the device will use to take its readings according to the max and min values that you specify in the DAQmx Create Channel VI.
Chris_K
(3,447 Views)
Thanks very much.
(3,435 Views)
